XDCAM EX missing in FCP
COW Forums : Sony XDCAM - EX & Related
Michael Ruiz
on Jan 30, 2010 at 1:30:39 am
Hi All
My FCP is missing the XDCAM EX Series Codec. Any Ideas?
Im running a Power PC Dual G5 with Leapord/ FCP 6.06 / Kona 2 - 6.03
Ron Pestes
Re: XDCAM EX missing in FCP
on Jan 30, 2010 at 1:52:04 am
You should be able to download the codec from Sony's website.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Michael Ruiz
on Jan 30, 2010 at 2:02:33 am
Thanks Ron
The Codecs are showing in my Additional FCP Easy Set Ups folder. hmmm. not sure why theyre not showing in FCP application. Also all the PRO RES files are not showing in FCP but exist in the Additional Easy Set Up folder..
Any Ideas?
m i c h a e l
Will Salley
on Jan 30, 2010 at 2:57:45 am
Try trashing prefs - all related to FCP.
Mac Pro 2x2.8 Quadcore - 10.6.2 - QT 7.6.3 - 22 GB RAM - nvidia8800GT - SATA internal & external storage - Blackmagic Multibridge Pro - Open GL 1.5.10 - Wacom Intous2 tablet - AJA io
SONY XDCAM EX3 - Letus Elite
Michael Ruiz
on Jan 30, 2010 at 3:15:16 am
Will trash Prefs...Where do I find them?
Will Salley
on Jan 30, 2010 at 3:46:26 am
On FCP 6 and higher:
Quit FCP.
Navigate to : User>Library>Preferences>Final Cut Pro User Data
In the "Final Cut Pro User Data" folder you will see more folder and several files. Drag all the files that have "Prefs" and "Cache" in the name onto the desktop and re-launch FCP.
Try the above, if that doesn't restore the settings, you may also need to trash Quicktime settings.
Also check here to see if the missing codecs are listed:
Mac HD (or whatever you name the boot drive)>Library>Application Support>Final Cut Pro System Support>Custom Settings
If you don't see the XDCAM codecs in that folder, you'll need to re-install the codecs.
Michael Ruiz
on Jan 30, 2010 at 4:10:13 am
Doing it now...will respond with results..Thank You Very Much!
Michael Ruiz
on Jan 30, 2010 at 4:15:46 am
Did the last suggestion and didnt work.. The Codecs do exist in the app support location .. hmmmm
Will Salley
on Jan 30, 2010 at 4:21:51 am
I guess the next thing to do is re-install the codecs from the Sony installer, but that still doesn't explain the ProRes codecs not showing up.
Michael Ruiz
on Jan 30, 2010 at 4:24:33 am
yea i dont get it .. will call AJA in the morning maybe they could help. They are super cool..Thanks for all your help !
Rafael Amador
on Jan 30, 2010 at 4:32:59 am
The Easy setups have nothing to do with the codecs.
Easy Setups are just FC templates for capturing or building sequences.
If XDCAM codecs would come in a component, this should be found in main/Library/ Quick Times.
But the XDCAM codecs are embed somewhere in FC.
Open any clip in QT and see if EX is in the list of available codecs.
If not, re-install the last FC update.
rafael
http://www.nagavideo.com
Michael Ruiz
on Jan 30, 2010 at 5:05:53 am
Working on that now ... thanks Rafael !
