Intercom thru Sony DXC-D30 cameras CCU
Chris Miller
on Jan 19, 2010 at 4:55:21 pm
Hi
I'm not sure if this is the right forum or not, but I thought I'd ask. I'm trying to figure out how to get ClearCom to plug into a Sony CCU-M5 and run down the 26-pin ccz-a cable and where it comes out of a Sony DXC-D30 camera. You can respond to cmiller@stagesound.com if this question is in the wrong thread.
Chris
john sharaf
Re: Intercom thru Sony DXC-D30 cameras CCU
on Jan 19, 2010 at 6:10:42 pm
Chris,
Although I am not familiar with that particular CCU, here is some information I was able to find via Google search:
Interfacing to Sony CCUs
We found three issues to deal with when interfacing Sony CCUs to Clearcom-type systems. Please review the circuit description and schematic diagram for the Clearcom-type system.
* Balanced vs. Unbalanced.
The Sony CCUs we have dealt with (CCU-M3 and CCU-M5) use balanced audio and the Clearcom analog system uses unbalanced. This was solved very simply with a small 1:1 audio transformer. We used a small (< 1-inch cube) surplus transformer we had, the kind that are used in dial-up modems. They don't have very good frequency response at the low end or the high end, but then that is actually desirable in an intercom. Limiting the bandwidth to voice frequencies reduces incidence of interference, noise, and distortion. transformers like this are commonly available from places like All Electronics, Digikey and Mouser.
* Signaling
The Clearcom system uses the same wire for both the intercom audio, and for signaling. The audio is AC coupled, and the signal is a DC component on top of it. We decided that we didn't need signaling out to the camera operators since: a) the camera operators are supposed to have their headsets on all the time; and b) the tally circuits built into the cameras and CCUs provide a "call" function. We just used a capacitor to AC-couple the Clearcom audio line to the transformer to keep DC out of the transformer.
* Audio Levels
This was the biggest problem. The Clearcom system runs at a significantly lower level than the Sony intercom. When we first devised the interface (just the capacitor and the transformer), it worked, but the receive level at the cameras was too low for practical use in noisy environments (like musical programs). And the microphones on the cameras were way too loud compared to the Clearcom intercom stations.
We use these cameras and CCUs almost exclusively in a production unit where all the control-room personnel (director, AD, TD, shader, tape operator, etc.) are using Clearcom-clone intercom stations. Because of this, we decided to modify the cameras to boost the audio level to the earphones in the camera op's headset, and to attenuate the mic signal. We made a very small (postage stamp size) circuit board with an op-amp booster and a volume control to knock down the mic level.
This has worked out quite well for us, but it might not be practical for everyone, and especially not for rental equipment(!) Actually, it wouldn't be hard to package the earphone boost and microphone attenuator into a very small external package which could be used with any camera, but it is not the elegant, no-modification solution we would have preferred.
So what it comes down to is an interface unit which connects between the Clearcom bus and the CCU bus (simply the transformer and capacitor); and another unit on each camera which boosts the earphone level and attenuates the mic level.
* CCU Interface Circuit
* Camera Amplifier/Attenuator Circuit
Feedback to: rcrowley dot com
Richard Crowley
on Jan 26, 2010 at 2:53:19 pm
Yes, that information is from my website. Note that because the Sony intercom levels are much higher than Clearcom, we had to modify the cameraas to accomodate the higher Clearcom audio levels. This is not very feasable unless you own the cameras and are willing to do the (modest) modifications.
The more conventional approach is to use the product(s) that Clearcom makes specifically for interfacing to Sony CCUs.
The direct URL for this information is:
http://www.rcrowley.com/ComClone/SonyCCU.htm
I provided the circuit schematic diagrams we used for both the interface and the camera mods.
We use the standard Clearcom 4-pin XLR headsets (vs the tiny 4-pin 3.5mm mini-phone that Sony used.) My head-shot photo here shows me wearing a pair of relatively inexpensive Koss headphones (with boom mic) that we retro-fitted with the Clearcom 4-pin XLR connectors. They worked just fine, but they are not nearly as rugged as the ones made for professional production.
