EX1 SDI 1080 output always interlaced?
Navarro Parker
on Jan 7, 2010 at 7:58:34 pm
I have my EX1 set to 1080P/24. When it records to the SxS cards, the resulting Quicktimes say they are 24p. And visually, they are not interlaced.
However, using a new Decklink SDI (which supports 1080/24P & 24PfS), I'm unable to see video.
So have you heard any problems if the EX1 outputs true 1080p via SDI? I can only get an interlaced SDI output when in 1080p mode.
At first, I thought 1080p would be too much for a single link SDI connect. But at 4:2:2 1080/24p, it squeaks under the threshold for single link SDI.
Alister Chapman
Re: EX1 SDI 1080 output always interlaced?
on Jan 10, 2010 at 6:44:47 pm
The output is PsF (Progressive Segmented Frame). It appears as an interlace signal, but within the interlace signal you have progressive frames. This is normal for 1080P OVER HDSDI
Alister Chapman
http://www.xdcam-user.com
maurice jansen
on Jan 10, 2010 at 9:45:48 pm
hi
look at page 105 of your EX1 manual
it tell's you how to change the HD-SDI output from 60I to 24PsF.
maybe it will help
grt
Maurice
People saying they don't make mistake's often make nothing at all!
