low audio monitor level
Mark Adamcik
on Nov 25, 2009 at 9:06:34 pm
Howdy all,
I wish I could raise the audio monitor level HIGHER (XDCAM EX PMW EX3). With the volume at max, it is still too low in my headsets. I've tried setting the audio output to monitor only Ch1 (interview mic) in both ears and it's still too low for me. Any help (or am I just getting too old)?
Also, I would like to see number markings on the audio meter in the viewfinder, as seen in the Audio Status screen.
Thanks.
Craig Seeman
Re: low audio monitor level
on Nov 25, 2009 at 9:23:27 pm
Perhaps it's your headsets. I use Sony MDR-7506 which sound fine.
Mark Adamcik
on Nov 25, 2009 at 9:54:24 pm
I'm using Sony MDR-7506.
I'm off...Happy Thankgiving!
Craig Seeman
on Nov 25, 2009 at 9:58:15 pm
Audio may be harder to hear while you're eating.
Kuhnen Brown
on Nov 26, 2009 at 8:12:03 am
Have you used the audio monitor adjustment buttons up on the handle?
George Griswold
on Nov 26, 2009 at 4:54:13 pm
Most of Sony's smaller cameras have lower than ideal monitor output levels. The Z1U was really really low. The EX-3 has just enough with the Sony headphones mentioned above. Noisy environments can be a problem if you are trying to confirm good audio on a lav mic.
Mark Adamcik
on Nov 30, 2009 at 1:28:02 pm
Thanks to all,
Yes, I've raised the monitor level on the handle to max. and the level is still too low for me.
A solution for me will be to use a small belt-pack amplifier we use for IFB to boost the signal from camera to headphone.
Thanks again.
