syncronize
Darius Cornean
syncronize
on Oct 31, 2009 at 4:22:25 pm
I have a problem with the synchronize between video and sound. I record with 4 camera, 3 Sony PMW-EX3 and 1 Sony HVR-Z7E. The sound its record detached and add it after with multicam.
when I import the files for multiclip the video files from Sony PMW-EX3 is synchronizing with the sound but the video files from Sony HVR-Z7E isn't synchronize. I cant figure why? can be a settings from the cameras or...? thanks for answering.
Ron Pestes
Re: syncronize
on Oct 31, 2009 at 7:29:17 pm
I am not positive on this but I think if the audio is recorded as 16 bit it can get out of sync. I had this happen with a DV tape and I had to slip the audio on the timeline to make it match.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Dean Sensui
Re: syncronize
on Nov 2, 2009 at 1:15:35 am
Check to see if the Sony HVR-Z7E is recording audio at 48 kHz. If the sample rate is different your sync could be thrown off.
If it's not at the same rate, then convert it with Quicktime or some other application where you can export an AIFF file at 48 kHz.
Dean Sensui -- Hawaii Goes Fishing
