EX-1 Camera Zoom used in tandem w/ 35mm Adapter?
Emile Wamsteker
on Oct 21, 2009 at 10:26:23 pm
When I mount my 35mm adapter to the front element of my EX-1 lens, I need to calibrate focus first, and then adjust the CAMERA's zoom so that the image fills the frame. If I don't adjust the Camera's zoom, I run the risk of vignetting.
My question is, once I've found the sweet spot and mark the zoom barrel, can I zoom in further if I wish--in effect using the camera's zoom as a tele-extender--and if so, to what extent. Will I have image degradation if I do? Or should I just leave it on the sweet spot, and treat it as a fixed focal length lens.
For example, when I have a 50mm prime mounted on the adapter, the EX-1's zoom is set to about 40mm to fill the frame. If the zoom is set wider, I get vignetting. Zoom tighter--to say 80m--and I am in effect changing the mounted lens' focal length, making it longer. I wonder if there is perceptible image degradation.
I am new to video, so judging whether or not there is degradation, is not easy for my eye to see but I wonder what others think and have observed.
Thanks in advance for your help.
Cheers,
-Emile
Bob Pierce
Re: EX-1 Camera Zoom used in tandem w/ 35mm Adapter?
on Oct 22, 2009 at 11:16:20 am
Yes. I do it all the time with my Letus, and have never noticed any degradation. Sometimes shooting interviews I need just a bit of flexibility with zooming (with a prime mounted). I wouldn't push it too much, though. Phillip Bloom has written about this and does it himself.
Bob
http://www.lightstreamassociates.com
Mac Pro 2.66 - 8GB memory -
Mac Book Pro 2.33 Duo -
FC Studio 2 - Kona Lhe
Adobe Production Suite CS4 -
Sony Multiformat 14" - Panasonic 42" Plasma -
Ikegami HLDV7 - PVW EX-1
Michael Palmer
on Oct 22, 2009 at 3:12:45 pm
Yes Bob is right, you can't push into the end, or at least I can't using the Red Rock Encore. The focus on the stock lens needs adjustment and I tape off the focus ring on the stock lens once I find the sweet spot.
I can count on Z73 to keep all of my Nikon lenses from vignetting and a few I can widen out a little more.
One thing to keep in mind is that a 28mm has a definitive look and feel and by zooming in on the stock lens it doesn't change and make it feel like a 35mm, it basically crops the field of view. I prefer to lock the stock lens at Z73 and change lenses to find the right composition.
Good Luck
Michael Palmer
Emile Wamsteker
on Oct 28, 2009 at 1:22:24 pm
Thanks Bob, and Michael,
This confirms what I thought, but needed reassurance from seasoned pros like you.
I've since run tests, and to my untrained video eye, I see no loss in quality when zooming into the subject using the EX-1 onboard zoom.
Thanks again for your comments.
Cheers,
-Emile
