Audio monitoring one channel only
Robin Probyn
on Oct 3, 2009 at 1:09:33 am
Hi
Is it possible to monitor say only ch1 from the minplug audio out .. couldnt find a switch on the body,or anything in the menu???
Rafael Amador
Re: Audio monitoring one channel only
on Oct 3, 2009 at 2:12:42 am
Look in the menu.
rafael
http://www.nagavideo.com
Robin Probyn
on Oct 3, 2009 at 2:16:28 am
Errr thanks,but as I say I did and couldnt find anything about it.. any more details as where in the menu..
Rafael Amador
on Oct 3, 2009 at 4:04:38 am
Menu Audio Set> Audio Output> Monitor CH.
rafael
Robin Probyn
on Oct 3, 2009 at 4:07:41 am
ah! many thanks.. I did see that but thought it was just for playback? that will also work for real time monitoring from the mini jack plug..?
thanks again for your time
Rafael Amador
on Oct 3, 2009 at 4:29:51 am
[Robin Probyn] " that will also work for real time monitoring from the mini jack plug..? "
Right.
A pleasure to help.
Cheers,
rafael
Robin Probyn
on Oct 3, 2009 at 4:34:01 am
You are both a learned scholar and a gent..
