XDCAM Transfer
Jim McNally
XDCAM Transfer
on Sep 22, 2009 at 8:35:15 pm
When I import my clips from XDCAM xfer into FCP can I put them directly into a bin? Right now they just dump into a project and then I have to sort them into a bin amongst all the existing files.
Jim McNally
The Commercial Factory
http://www.commercialfactory.com
Noah Kadner
Re: XDCAM Transfer
on Sep 22, 2009 at 11:40:29 pm
Have you tried setting a logging bin in FCP?
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
DSLR Cinematography Blog
Craig Seeman
Re: XDCAM Transfer
on Sep 23, 2009 at 12:19:08 am
I believe I tested setting a logging bin once and it didn't seem to work. It was a while ago.
That's one reason why I use a two step process of rewrap first and then import into appropriate bin.
Jim McNally
Re: XDCAM Transfer
on Sep 23, 2009 at 12:22:38 am
I started with setting a logging bin but still went to project.
Craig what is the process you use?
Jim McNally
Craig Seeman
Re: XDCAM Transfer
on Sep 23, 2009 at 12:27:04 am
I open XDCAM Transfer as a separate app and target a destination folder rather than an FCP project.
Once everything is re-wrapped, I import into FCP from the destination folder in the appropriate bins.
Paul Crowe
Re: XDCAM Transfer
on Sep 23, 2009 at 1:29:19 am
In Media 100 all you do is create a new bin and import straight into it direct from transfer tool - seamless! Surely it works as easily as this in FCP?
Cheers
Paul
Jim McNally
Re: XDCAM Transfer
on Sep 23, 2009 at 2:11:06 am
Okay, thanks Craig I'll have to try that approach. That would still be better than Paul's suggestion of having to using Media 100 to do it...four years was enough!! lol
Jim McNally
Michael Slowe
Re: XDCAM Transfer
on Sep 23, 2009 at 5:17:32 pm
There you are Jim, Media 100 is better! I honestly believe it's still the best and most logical NLR. Certainly as far as importing via the EX Transfer it is straightforward enough.
Michael Slowe
Jim McNally
Re: XDCAM Transfer
on Sep 23, 2009 at 2:11:53 am
Do you include the FCP xml files with it?
Jim McNally
Clint Fleckenstein
Re: XDCAM Transfer
on Sep 23, 2009 at 2:14:15 pm
I just tried importing using the XDCAM transfer plug-in to FCP and got the same result as you did. Even by flagging a bin as the Logging Bin, opening it, and right-clicking to import Sony XDCAM. Imported files just went to the main project window. Weird.
I don't normally import footage this way so I hadn't noticed that.
Cf
Noah Kadner
Re: XDCAM Transfer
on Sep 24, 2009 at 1:16:09 am
You can always just move into a new bin after each ingest- I don't see it as a big deal. FCP knows where the files came from regardless it just makes your life a bit more organized.
Noah
Fabrizio Fantini
Re: XDCAM Transfer
on Sep 23, 2009 at 4:37:07 pm
wich kind of shoot you make?!
