EX1 - Disable Some Options
Peter Chambers
on Aug 26, 2009 at 9:42:58 pm
Hi guys,
How do you disable:
1) The red record light while recording.
2) That annoying beeping sound when battery is low?
Thanks.
Michael Slowe
Re: EX1 - Disable Some Options
on Aug 27, 2009 at 10:33:43 am
You can certainly disable the light, front and back but I can't remember which menu it's under, just scroll through to find it. As to the battery bleep I don't think you can disable that one, I know you can't do that with the low media bleep. They stop when you are actually shooting but come on while in 'standby' which can be a nuisance. There are bleeps which you can disable, just search through the menus, it's all there.
Michael Slowe
Michael Palmer
on Aug 27, 2009 at 2:17:32 pm
The red light is a Tally light and you can turn if off from the Others menu (at the bottom of the main sub menus) and you can turn on/off the front tally as well as the rear.
In this same Others menu is the Battery Alarm can be set as low as 5% remaining and I don't believe it can be turned off.
I was using the Anton Bauer Gold Mount that plugs directly into the DC in port and I can tell you that when the Anton Bauer battery dies there is no warning, and for me I am use to this warning beep.
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=584274&Q=&is=REG&A=d...
Good Luck
Michael Palmer
Peter Chambers
on Aug 27, 2009 at 9:06:30 pm
Ah...tally, thanks. I didn't know it was called that.
