EX3/FCP Settings for SD
John Warren
on Aug 14, 2009 at 12:47:52 am
Our unit just got Sony EX3 video cameras. We edit using Final Cut, and broadcast in Standard Definition. I need to knowwhat Video Format settings, and which Shutter setting I should choose so we can properly ingest the video we shoot into Final Cut, and how to output for broadcast in SD. Right now, with anything we shoot, horizontal lines "smear" and ziz-zag. The benefit of your advice is greatly appreciated.
V/r,
JW
Macc Pro G5
Quad-Core Intel
16 GB
1.6 GHz
Final Cut Pro 6.0.6
Noah Kadner
Re: EX3/FCP Settings for SD
on Aug 14, 2009 at 1:09:50 pm
Capture HD, edit HD match your capture to shoot settings. There are presets for the most common- like XDCAM EX 1080/24p; 720/24p, etc. Then output the final version as 16:9 ProRes 720x480 SD, that will give you a solid SD master.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
John Warren
on Aug 14, 2009 at 9:37:28 pm
Thanks a million for your help, Noah! I'm back on track and the image is fine now.
V/r,
John Warren
Vitória Dias
on Jan 18, 2010 at 5:07:40 pm
Hi
same question but to export for web
thank you so much
Vi
