Best quality interlaced quicktime
COW Forums : Sony XDCAM - EX & Related
Andrew Mula
on Jul 27, 2009 at 2:10:11 am
Hi guys,
I'm new to the EX-3 camera and am learning how to export EX 1080i50 footage to H.264, ProRes, uncompressed and SD interlaced quicktimes.
The main issue has to do with long GOP structure and getting the interlaced footage to look decent.
At the moment I am getting field/frame issues that aren't blending correctly. The only way I've got to work thus far is to de-interlace the footage on the timeline but don' think that's a great option going forward.
Rather than bang on about all the things I've tried, any links, suggestions you have would be awesome.
10.4.11. FCP Studio 2. Anything that's worked for your workflow I'd sure like to hear about :-)
Many Thanks
Rafael Amador
Re: Best quality interlaced quicktime
on Jul 27, 2009 at 4:58:14 pm
Hi Andrew,
Compressor will make a very good job for resizing, de-interlacing and change the time-base, as long as you set the "Frame Control: ON".
It shouldn't have any problem in de-interlacing, re-interlacing or shifting the field order.
© 2018 All Rights Reserved
