EX3 rec button malfunction (plus some shoots)
Enrique Orozco
on Jul 13, 2009 at 4:16:49 pm
... very happy with the EX3, however suddenly my main rec button began to fail.... as if it were "moved" or "broken" inside the rubber cover.... I'm preparing to send the camera for service but want to share the experience with other users that maybe have had similar problems .... any comment would be welcome....
...some EX3 shoots from my town:
kind regards
Enrique Orozco R.
http://www.dvideostudio.com >iDEA DigitalVideoStudio
Michael Palmer
Re: EX3 rec button malfunction (plus some shoots)
on Jul 13, 2009 at 4:29:18 pm
I had the rubber cap become jammed and had to loosen the grip and I was able to reset it. If I remember correctly it rotated and it is definitely something you can fix.
Good Luck
Michael Palmer
enrique orozco
on Jul 13, 2009 at 5:26:25 pm
Thank you Michael .... Do you "open" the grip, or just manipulate the rubber cover ?? ... I tried to "take off" the rubber cover in order to find and "fix" the button, but it was very difficult or "risky" ...is that easy ??
kind regards
Enrique Orozco R.
Michael Palmer
on Jul 13, 2009 at 5:55:40 pm
I think I opened the grip and reset the button. It wasn't hard to do so if you are careful it should save you the time lost of taking it in for service.
Good Luck
Michael Palmer
enrique orozco
on Jul 13, 2009 at 6:26:05 pm
Thank you... I'll check your suggestion ...
Regards
Enrique Orozco R.
