FCP XDCAM transfer can't import TGV K2 XDCAM MXF
bk kim
on Jun 5, 2009 at 7:07:56 pm
Dear Sir
I just test with TGV K2 media server MXF file in the FCP XDCAM transfer software, but it couldn't import with below error message
"Invaild SMPTE key.."
Have you tested with TGV K2 media server MXF file (XDCAM 422 50M) to import with FCP XDCAM software?
Is this possible? or not?
Andy Mees
Re: FCP XDCAM transfer can't import TGV K2 XDCAM MXF
on Jun 7, 2009 at 7:41:18 am
Kim
This is not possible. Sony's XDCAM Transfer is not a universal MXF import/export tool for FCP, it is specifically and solely for interfacing with Sony's own XDCAM media. If you need to work with Thomson Grass Valley k2 based clip media then you need the GV-Connect component from TGV ... I do not know whether this is publicly available yet
http://k2san.blogspot.com/2009/04/new-at-nab-2009-gv-fcp-connect-plug-in.ht...
Also you can try using Filp4Mac's K2 Profile Component, however I believe it does not currently support XDCAM HD 422 50Mbps footage.
http://www.telestream.net/mxf-final-cut-pro/mxf-component-k2profile.htm
Good luck
Andy
