xdcam transfer for PC
Randy Lincks
on May 19, 2009 at 8:54:08 pm
I have just purchased the exI and work on PC. I need to output a 10 bit uncompressed HD QuickTime files. Is there any other way to do on PC. Thanks in advance
Craig Seeman
Re: xdcam transfer for PC
on May 20, 2009 at 5:04:08 am
[Randy Lincks] "I need to output a 10 bit uncompressed HD QuickTime files"
Why such a need?
Why would this be a problem if there is such a need?
[Randy Lincks] "Is there any other way to do on PC"
Other than what?
You haven't mentioned a desired workflow or what the problem is. Without that, no one can answer a question because there's no clear question.
Wrap to MXF in ClipBrowser. Drop EX MXF in good compression app. Export to 10 Bit Uncompressed HD Quicktime.
Had you posted info you might have had an answer already.
