SD card recommendations
Rod Minott
on May 14, 2009 at 7:28:57 pm
I’d like to purchase 32GB SD cards and plan to use them with MxR Expresscard readers in my Sony EX3. What brand of 32GB work best and where can they be purchased?
Craig Seeman
Re: SD card recommendations
on May 14, 2009 at 9:07:02 pm
Transcend SDHC Class 6 32GB seems to be the only reliable one right now.
The older Sandisk Ultra II Class 2 32GB worked but the newer Class 4 do not.
Rod Minott
on May 14, 2009 at 9:08:57 pm
Thanks. Any recommendations on where to purchase them: Amazon, J&R? I don't believe B&H carries Transcend.
Craig Seeman
on May 14, 2009 at 9:23:07 pm
I'd trust J&R. They have an easy return exchange policy.
Rod Minott
on May 14, 2009 at 9:27:45 pm
Thanks much!
neil Jay
on May 14, 2009 at 9:15:35 pm
Why not go with two 16gb cards? Better value and less risk in case of card failure (only loose one hour as opposed to two).
Neil
http://www.reactionstudio.ca
Craig Seeman
on May 14, 2009 at 9:26:35 pm
[neil Jay] "Why not go with two 16gb cards?"
Because one may want to go more than two hours and not have to change cards.
[neil Jay] "less risk in case of card failure (only loose one hour as opposed to two). "
INMHO the act of changing a card can be a risk for many reasons. 4 hours can stay in the camera for nearly all my shoots. I don't have to change cards at all. To me that's least risky. Nothing in pocket or bag to lose. No having to open the slot door while camera is rolling. If I lose 1 or 2 hours the shoot is tanked either way. Not having to change cards is one less risk and often a lot less risk IMHO.
Rod Minott
on May 14, 2009 at 9:33:37 pm
Ditto for me. I agree with you Craig. Thanks.
Kerry Brown
on May 15, 2009 at 2:01:51 am
ChiTek is fine. Good service. Get the reader combo also. Works great.
TS16GSDHC6
http://www.amazon.com/Transcend-Class-Memory-Reader-TS16GSDHC6-S5W/dp/B0010...
KB
Rod Minott
on May 15, 2009 at 5:10:44 pm
Newegg also has them for $112:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820208480
