Ground Glass artifacts with Letus Extreme
Colby Gottert
on Apr 30, 2009 at 3:42:37 am
I have noticed that when using the Letus Extreme on the EX1 that I can see traces of the ground glass (even when it is vibrating) when I have the fixed lens set to a higher f-stop. For example, f8 leads to more artifacts than f4 and f 4 in not as clean as f1.8.
I have put some video up on my blog:
http://www.colbygottert.com
Has anyone else noticed this?
Jeff Regan
Re: Ground Glass artifacts with Letus Extreme
on Apr 30, 2009 at 6:22:18 pm
This is a well known limitation of most oscillating glass 35mm adapters. You don't want to close down more than f5.6. Shutter speeds should be kept low as well.
The Letus Ultimate can be stopped down as far as you want without seeing the ground glass because it spins vs. oscillates. However, even the Ultimate should not be used with shutter speeds higher than 1/500th.
Jeff Regan
Shooting Star Video
http://www.ssv.com
