Problem Exporting
Felipe Arias
Problem Exporting
on Apr 19, 2009 at 7:26:34 pm
When I try to export the movie from the timeline, the result looks like this. (plesase follow the link)
http://farm4.static.flickr.com/3396/3437170720_6b68bae5e4_b.jpg
The video also looks like this in the timeline, nevertheless when I am editing, it looks fine.
I tried importing the footage on Imovie, and its the same...
I am using FINAL CUT PRO academic 6.0.5
on a Mac OS X version 10.5.6
I have a Mac pro
I've checked the sequence settings
frame size: 1920 x1080 HDTV1080i (16x9)
pixel aspect ratio: square
editing timebase: 23,98
quicktime video settings:
compressor: xdcam ex 1080p24 (35Mb/s vbr)
quality: 100%
audio settings:
rate: 48Khz
depth: 16 bit
config: channel grouped
thanks in advance
Craig Seeman
Re: Problem Exporting
on Apr 20, 2009 at 3:26:20 am
Do you have the Calibratedsoftware plugin installed?
It looks like that in demo mode.
It shouldn't be used on FCP systems as it'll conflict with FCP's on EC codec. It's meant for non FCP systems specifically.
Felipe Arias
on Apr 20, 2009 at 4:09:05 am
Thanks for the reply
I really don't know if I have that plug in installed in this computer. How can I find out?
Craig Seeman
on Apr 20, 2009 at 6:31:19 am
Look in your system's Quicktime folder and look for the word Calibrated.
Felipe Arias
on Apr 21, 2009 at 2:06:27 am
I found the calibrated component installed, how can I erase it or uninstalled it?
thank you!
Craig Seeman
on Apr 21, 2009 at 2:33:25 am
http://www.calibratedsoftware.com/downloads/ReadMe-Calibrated{Q}XDDecode.pd...
On page 2 of the PDF
To Uninstall:
1. If Licensed, backup CalibratedComponent.lic file to a temp directory.
2. If no other Calibrated Software is installed, then delete the directory:
/Applications/Calibrated
3. If other Calibrated Software is installed, then only delete:
a. /Applications/Calibrated/Applications/Options/CalibratedQXDOptions.app
b. /Applications/Calibrated/Plugins/QuickTime/CalibratedXDCodec.component
c. /Applications/Calibrated/Docs/CalibratedQXDOptions.pdf
d. /Applications/Calibrated/Docs/ReadMe-Calibrated{Q}XDDecode.pdf
4. Delete the file:
/Library/QuickTime/CalibratedXDCodec.component
5. Delete the file:
/Users/[user]/Library/Preferences/com.calibratedsoftware.CalibratedXDCodec.plist
