Accessing BVAV files from external drive
Chris Cooke
on Apr 13, 2009 at 6:13:20 pm
When out shooting, my cameraman didn't have any room left on his SxS Pro card and therefore, he copied the BVAV files to his external hard drive which was connected to his PC Laptop. I am now trying to import them into FCP on my Mac Pro using XDCAM Transfer Utility without success. Can you help?
Chris Cooke
Feature Productions
http://www.featureproductions.ca
cooke@featureproductions.ca
Craig Seeman
Re: Accessing BVAV files from external drive
on Apr 13, 2009 at 6:25:21 pm
And he did this using ClipBrowser with CRC checking on of course?
Put the BPAV in a parent folder and see if that helps.
Is the hard drive formated FAT32 or NTFS?
"without success" is vague.
If you posted all the info you might have had an answer by know. No offense intended but if people want quick responses they really need to post ALL THE DETAILS otherwise the doctor may recommend amputation instead of an aspirin.
Noah Kadner
on Apr 13, 2009 at 10:53:22 pm
Yeah what area is failing- can you even mount the drive on your desktop?
Noah
Check out my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Ed Kukla
on Apr 15, 2009 at 8:38:37 pm
Won't you need pc to mac file conversion software?
Craig Seeman
on Apr 15, 2009 at 8:51:14 pm
[Ed Kukla] "Won't you need pc to mac file conversion software?"
FAT32 drive, no problem.
NTFS should be readable but would require software to write to.
He's only reading in this case.
Chris Cooke
on Apr 17, 2009 at 4:03:57 am
Thanks for the help guys...
The cameraman named each folder BPAV1, BPAV2 and so on. After much frustration, I realized that I just need to create separate folders with each of these BPAV folders inside and named "BPAV". I guess XDCAM Transfer only recognizes that specific folder name.
Chris Cooke
Feature Productions
Don Greening
on Apr 17, 2009 at 4:17:38 am
[Chris Cooke] "I guess XDCAM Transfer only recognizes that specific folder name. "
Correct. If the name "BPAV" is altered in any way the workflow process will grind to an immediate halt. Always create a uniquely named parent folder for every BPAV folder.
- Don
Craig Seeman
on Apr 17, 2009 at 4:33:45 am
Hmm, if you told us all the information you'd have had the correct answer four days ago.
Sigh!
Ed Kukla
on Apr 17, 2009 at 10:44:11 am
On a tangent...
I did a test the other day with a clients editor. he used the XDCAM transfer utility to offload EX clips. What is the difference between the Transfer utility and Clip Browser. I told him he must use clip browser but he downloaded clips with out it.
Craig Seeman
on Apr 17, 2009 at 3:40:00 pm
On Windows ClipBrowser both copies and wraps to MXF (which Mac version does as well)
On Mac XDCAM Transfer add the wrap to MOV and some improved logging tools.
[Ed Kukla] "I told him he must use clip browser but he downloaded clips with out it."
I guess he refuses to wear seat belts when he drives too.
