message
Ron Couvillion
message
on Mar 18, 2009 at 12:11:43 am
When I change my gain settings, I get this message, "Cannot proceed" and the gain does not change.
stephen may
Re: message
on Mar 18, 2009 at 1:02:08 am
Ron, If you mean the video gain (sensors) - I'm not getting that message, and am able to set the three settings, however, if you mean the audio gain settings for mic input CH 1 and CH2, you must have the switch on the rear of the camera set to EXT (external) in order to adjust those. -s
Stephen May
Keystone Media Productions
Freelance Videographer
Craig Seeman
Re: message
on Mar 18, 2009 at 1:08:31 am
You probably have Direct Menu set to All. Go into the menu Others/Direct Menu and set to Part.
stephen may
Re: message
on Mar 18, 2009 at 1:25:46 am
Craig - what does that mean, and what's the difference between 'all' vs 'part'?
Stephen May
Craig Seeman
Re: message
on Mar 18, 2009 at 1:46:00 am
It's menu control.
If one tries to change the Gain setting using the controls on LCD you can get "cannot proceed" unless you go into the "Other" menu in the camera and change Direct Menu to Part which allow you to make the change using the LCD.
