PHU-60K with HVR-Z7 possible?
din noor
on Jan 20, 2009 at 4:15:48 am
i do understand that the PHU-60K is meant to use with PMW-EX series. Has anyone tried using the 6OK with HVR series camcorders? pls advise..thks
Din
be calm & patience.
Craig Seeman
Re: PHU-60K with HVR-Z7 possible?
on Jan 20, 2009 at 4:36:26 am
You'd probably want the Sony HVR-DR60.
The PHU-60K has an SxS (Express card) connector.
Why try to fit a square peg in a round hole so to speak? Do you have a reason for trying to use the PHU-60K instead of the HVR-DR60?
din noor
Re: THANK YOU
on Jan 21, 2009 at 3:48:20 am
Craig,
thks for the advise & recommendation..me will get the HVR-DR60..
be calm & patience.
