SxS reader question
dano motley
SxS reader question
on Jan 6, 2009 at 2:30:08 am
i have found two internal SxS readers for my pc. both are made by a company called Siig. one reader is usb 2.0 and the other is pcie. they are both mountable in a 5.25 opening in the case. my question is.... is there a difference between them as far as speed of transfer, etc. when ingesting clips from the SxS cards?
thanks in advance,
dan
Craig Seeman
Re: SxS reader question
on Jan 6, 2009 at 3:08:34 am
Do you know about Synchrotech?
http://www.synchrotech.com/products-expc/pcie-expresscard-slot-drive_02.htm...
It's both PCIe and USB.
Look at these from them
http://www.synchrotech.com/products-expc/pcie-expresscard-slot-drive_00.htm...
Please note that they specifically address SxS issues.
Generally you can't hot swap the cards. On certain Windows boxes you can force a search for new hardware each time you swap otherwise your faced with a reboot on each swap.
SxS is PCIe, not USB
If you look at MxR, those are USB.
Craig Seeman
on Jan 6, 2009 at 3:10:16 am
See their comments here specific to SxS
http://www.synchrotech.com/support/tech-notes-hot_swapping_pcie_based_expre...
dano motley
Re: SxS reader question - for craig
on Jan 6, 2009 at 9:05:45 pm
the store also has a siig that has both pcie and usb 2.0 simultaniously. i believe this would allow you to hot swap the cards. i think this would work the same...no?
http://siig.com/ViewProduct.aspx?pn=JJ-000082-S1
the price is $59.00
thanks again,
dano
Craig Seeman
on Jan 6, 2009 at 9:16:28 pm
Hot swap issue is a problem relating to the bios apparently and because PCIe was not designed to be hot swappable. Read the Synchrotech message. It doesn't work. On Windows scan for new hardware might work. At least Synchrotech did their homework and posted honestly because they were getting inquiries from potential buyers. I don't think SIIG's technology is any different.
My bet is that the SIIG reader won't hot swap.
