Odd Situation with XDCAM
Aaron Cadieux
on Dec 17, 2008 at 5:28:01 pm
OK, here goes. This will probably seem confusing, so I'll explain it the best I can.
I have the Blackmagic Multibridge Pro. I cut on Premiere Pro CS3 with the XDCAM update. As of right now, the Blackmagic Decklink software does not support XDCAM. So, I have imported my .mxf files into an XDCAM project. I then re-exported the files using the "Blackmagic HD 8-bit 4.2.2" Codec. I set the frame size to 1440 by 1080. I set the frame rate to 59.94 to match the frame rate of the original 59.94i XDCAM footage.
Once the footage is exported, I open a Blackmagic preset project in Premiere. I use the Blackmagic Interlaced 59.94 8-bit HD preset for the project. I then import the footage I converted using the "Blackmagic HD 8-bit 4.2.2" codec from the XDCAM project. In theory this footage should not require rendering. However, it does. What is the reason for this, and why is it happening? Let me know if I need to explain this better.
Thanks.
Aaron
Aaron Cadieux
Re: Odd Situation with XDCAM UPDATE
on Dec 17, 2008 at 5:32:07 pm
UPDATE.
I am trying this again using a frame size of 1920 x 1080 when re-exporting with the Blackmagic Codec. I will let you all know if it works.
-Aaron
Rafael Amador
on Dec 18, 2008 at 9:45:15 am
Yeah. I think you should export 1090x1080 Square Pixels.
Rafael
http://www.nagavideo.com
