century 6x wide angle lens adapter on SONY EX3
COW Forums : Sony XDCAM - EX & Related
Din noor
on Dec 11, 2008 at 9:26:10 am
dear xperts,
recently i bought the above mentioned adapter for my sony ex3.
At my fullest zoom out i could see black edges, but when i zoom in a bit the edge become thicker & at a point where i zoom in till i could do focus, the edges are gone.
when i use it on panasonic 202 cam, it looks fine..pls advise.
thks
Din
be calm & patience.
jason myer
Re: century 6x wide angle lens adapter on SONY EX3
on May 16, 2011 at 8:50:58 pm
I am running into the same issue. I think I've narrowed it down to the zoom ring. I manually move the zoom ring a few times back and forth fully and the issue fixes itself. I've yet to have this happen while filming...in other words...it happens when I turn on the camera. But once I fix it...I don't have the problem come back until I turn off the camera. Since I'm a wedding videographer and leave my camera on a lot, and have plenty of batteries to do so, and can fix the issue quickly and consistently, I've decided to not send the lens in for repair...at least that is my current plan
Rafael Amador
on May 16, 2011 at 9:36:08 pm
Hi Jason,
I think that's nothing about the lens. You are describing a Back-focus problem (very typical in EX-1/3).
Are you checking the "wide lens" option in the EX menu?
rafael
BTW, keeping this
http://www.nagavideo.com
jason myer
on May 16, 2011 at 9:46:46 pm
Hi Rafael,
thanks for the quick reply! Are you referring to the "Wide Conversion" option off the menu or something else? Thank you
