XDCAM2FCP2Flash6 creates fuzzy results
William McCauley
on Dec 4, 2008 at 3:47:05 am
Not sure where to really put this one so I thought I begin at the front of the workflow.
Problem is slightly fuzzy results in Sorenson Squeeze codec for Flash 6 player.
We have used with EX-1 and 3, PDW330 &350 cameras at 1080P 35HQ- edited in FCP and cropped to 4x3, Exported to master Quicktime file using the xdcam settings. The file is then processed in Sorenson v4.8 to create a 400x300 Flash 6 compatible swf file. The image results are a touch soft compared to using the same workflow with DV cam sources or XDCAM at 720P. On the surface it seems like I'm shooting a gnat with a cannon but the results are puzzling. Generally when you shrink bits images can get sharper not softer.
Any Ideas...
Rafael Amador
Re: XDCAM2FCP2Flash6 creates fuzzy results
on Dec 4, 2008 at 12:18:05 pm
[William McCauley] "Exported to master Quicktime file using the xdcam settings. "
Hi William,
The XDCAM codecs are for acquisition. You better export in any other codec, like ProRes.
Cheers,
rafael
http://www.nagavideo.com
