EX3 Flicker Reduce mode?
COW Forums : Sony XDCAM - EX & Related
Chris Stevens
on Oct 20, 2008 at 8:48:55 am
The manual does not explain "Flicker Reduce Mode". I assume it's a preset shutter speed for either 50 or 60 Hz. Am I somewhere near the mark?
G5 dual 2.7, OS10.5.1, 4G RAM
Media100 HD V12 & Producer, AE 7
5.6 terra RAID
Don Greening
Re: EX3 Flicker Reduce mode?
on Oct 20, 2008 at 5:14:53 pm
[Chris Stevens] "The manual does not explain "Flicker Reduce Mode"."
Actually, the manual does talk about it to some extent on pages 50 and 98, at least in the EX1 manual. To sum up, you can set the flicker reduce function to:
- be on all the time
- set to auto where it only activates when flicker is detected
- off
You can also set the frequency to 50 Hz or 60Hz, so you're right on the mark. The manual also states:
"If the frame rate selected for recording is close to the power supply frequency, flicker may not be reduced sufficiently even if you activate the Flicker-Reduce function. In such cases, use the electronic shutter."
This last statement is Sony's disclaimer or "get-out-of-jail-free" card with regard to how well the function will...........function.
- Don
