EX3 & Firestore & 35mm Adapters
COW Forums : Sony XDCAM - EX & Related
Mark Espina
on Sep 16, 2008 at 1:49:41 pm
Hi!
Two questions:
1) Can you use a Firestore with the EX3?
2) Can you mount a 35mm lens adapter (mini35, letus, brevis, etc....) straight onto the body of an EX3?
Cheers.
Scot Lenter
Re: EX3 & Firestore & 35mm Adapters
on Sep 16, 2008 at 2:24:52 pm
Mark,
The portable hard drive that can be used with the SxS format is the Sony PHU-60K. It is a 60Gb hard drive.
I don't know that you can attach a 35mm adapter to the body of the EX-3 but you can get the 77mm adapter and attach one to the end of the lens, same as you would on an EX-1.
Scot Lenter
Midtown Video
Miami, Florida
Service Manager
Rental Agent
scot@midtownvideo.com
305-669-1117
Mark Espina
on Sep 17, 2008 at 1:51:58 am
Hey Scott,
Thanks for your reply.
The PHU-60k is indeed what I was looking for.
Regarding the 35mm adapter connecting straight to the body of the EX3, I got that idea after finding this in vimeo:
http://www.vimeo.com/1542171
And was answered in an article I found when I went to look for info on the PHU-60K.
Apparently Letus is creating a 35mm adapter to fit straight onto the body of the EX3. You can read the artilce here:
http://www.dvuser.co.uk/content.php?CID=174
Thanks again.
