XDCAM Clip Browser Split Folder
COW Forums : Sony XDCAM - EX & Related
Wendi Koble
on Aug 25, 2008 at 8:03:11 pm
I'm trying to split a folder on a 16GB card and in the clip browser, it's grayed out. Any thoughts to why this is happening? I just upgraded to 2.0 and I've read the manual, searched the posts and I can't find anything about this problem. The card is not right-protected. I'm using MAC OS 10.4.11. It's just one 36 minute clip I'm trying to split so I can archive onto Dual layer DVDs. I hope I've included all the necessary info.
Thanks in advance,
Wendi
cowcowcowcowcow
Craig Seeman
Re: XDCAM Clip Browser Split Folder
on Aug 25, 2008 at 8:46:01 pm
[Wendi Koble] "it's grayed out."
I'm not quite sure what is grayed out. Can you access the clips and play the files in the ClipBrowser.
ClipBrowser 2 works a bit differently that ClipBrowser1.
First I use CB2 to copy to a new folder. I then split in that folder. I used to be able to split right on the source SxS card but it doesn't seem to do that anymore.
Wendi Koble
on Aug 25, 2008 at 11:57:47 pm
Thanks Craig!
That's gotta be it. I was expecting the program to work the same. Thanks for your help!
