SxS Recording Time w/720P
COW Forums : Sony XDCAM - EX & Related
Bob Douglas
on Aug 21, 2008 at 4:07:24 pm
Experienced EX1 Users,
When using the EX1 SxS cards do you get any extended recording time beyond the Factory Specs when shooting 720P 23.98fps?
One would think with a shorter framerate and smaller frame, that the card could record more minutes, but I'm looking for info from actual users?
The Factory specs are stated at 1080i
HQ: 50 min
SP: 70 min
HQ: 25 min
SP: 35 min
Bob Douglas
FX Productions
Craig Seeman
Re: SxS Recording Time w/720P
on Aug 21, 2008 at 5:13:53 pm
Unlike P2/DVCProHD where data rate is tied to the frame, XDCAM data rate is based on time. 1 second of video, regardless of frame size or rate is 35mbits VBR. There some ability for it to vary but basically the data rate is the same. In HDV compatible mode it's 25bits CBR hence you get longer record times.
So P2/DVCProHD uses much less data when recording 720p24 compared to 720p60 or 1080 for example. This is NOT the case with XDCAM. Personally I'm glad XDCAM does NOT work that way. I can then choose my recording mode best on what's best for the job rather than trying to extend record time to the a card. While it's true that at 1080 you're spreading that data over more pixels on a frame compared to 720 and the data for a given frame will be different for 24 vs 60 as well but I find those choices more reasonable then limiting myself to 720p24 to try to increase record time.
© 2018 All Rights Reserved
