EX-3 render time?
COW Forums : Sony XDCAM - EX & Related
Jeremy Carter
EX-3 render time?
on Aug 2, 2008 at 1:51:18 am
Looking to buy two Ex-3s for studio use and wanted to know if there was any render time with the codec after going thru Sony's transfer software into Final Cut Pro 6?
Don Greening
Re: EX-3 render time?
on Aug 2, 2008 at 3:31:59 am
Final Cut Pro 6.0.2 and newer has the EX codec that's required to display and edit the footage from the EX1 and EX3 cameras. If the FCP sequence settings match the EX clip settings then there is no "render time", if this is what you're referring to. This means you can play back and edit transferred EX footage in real time right away. Adding effects to EX clips within FCP will result in the same type of rendering times as other Long GOP codecs.
- Don
Craig Seeman
on Aug 3, 2008 at 3:47:05 pm
You can set your sequence to the EX codec but have it render in AppleProRes (you can do this for HDV too). This means there's no GOP reconform while editing/rendering FX. Easy setups don't default to this so you click on your Sequence/Settings/Render Control/Codec/Apple ProRes 422.
Jeremy Carter
on Aug 4, 2008 at 7:00:25 pm
Thank you very much. This is exactly what I wanted to know.
