XD CAM IMPORT ERROR TO FCP
COW Forums : Sony XDCAM - EX & Related
Annu Lilja
on May 25, 2008 at 8:02:36 am
I have a lot of XD CAM material that I have imported to final cut using XD CAM TRANSFER.
Some clips won't transfer, though. These are clips starting with SMI, or subclips of these clips.
One error message I get is:
NSFC Data writeTo File:options:error:
nil file argument
Other times the program suggests that my drive is too full, which is not the case.
PLEASE HELP!
Thank you.
Annu
Michael Palmer
Re: XD CAM IMPORT ERROR TO FCP
on May 25, 2008 at 4:29:26 pm
I believe you have clips that either were over 4 gigs or have crossed to another card.
In the case of a clip being over 4 gigs you will see the SMI file and perhaps 2 files that end with -1 then -2, highlight the clip and down in the information box, i believe under the subclip you will see a check box for these clips, make sure they bother are checked. If you have clips that have crossed to a second card you will need to add an end mark to the first half as if you were making a subclip.
Good Luck
Michael Palmer
Robert Dexter
on May 27, 2008 at 7:14:07 am
What version of XDCAM Transfer were you using?
This trouble might have been fixed in the latest version 2.7, which you could get from here:
http://www.sony.co.uk/res/attachment/file/41/1203501582241.dmg
