XDCAM transfer doesn't see my archioved BPAV folder files
COW Forums : Sony XDCAM - EX & Related
Bill Snyder
on Apr 21, 2008 at 9:32:06 pm
I copied my BPAV folders from my SXS card to my hard drive. Like I
was tutored in the Vortex DVD.
When I physically open up the folders I can see the MP4 files and meta data in there.
I open XDCAM Transfer 2.1 on my Intel Mac using OS 10.5.2 (Studio 2)
and when I chose the source folder BPAV1, XDCAM Transfer says NO
files are in there. What is wrong?
I even slipped my SXS card with files on it in the slot of my MBPro and I get the same error in XDCAM TRANSFER.
Do any of you guys know what is up with this?
I poke around and can't intuitively figure this out.
Thanks for any help you can bring, this is rather unsettling in that I bumped
4 sets of SXS files off the card to my drive and now want to see the clips
but can't, and of course the clips are very important non-repeatable events.
Chris Babbitt
Re: XDCAM transfer doesn't see my archioved BPAV folder files
on Apr 21, 2008 at 9:51:43 pm
I believe the BPAV folder must be inside another folder.
Craig Seeman
on Apr 21, 2008 at 10:23:59 pm
Yes BPAV must be inside another folder and you should update to XDCAM Transfer 2.5.1
Bill Snyder
on Apr 22, 2008 at 1:43:14 am
Hey thanks Craig, I got the same tip from Chris and Ken Stone. However I still a problem.
The files now load in XDCAM but I can't see them, no thumbnails or image in the main viewer.
The one clip still on my SXS card shows on the camera fine but like the archived dumps, it doesn't show in XDCAM Transfer.
Maybe some setting in 2.5.1 I'm not aware of?
Thanks for any help you can offer, it's greatly appreciated!
Bill Snyder
ken hon
on Apr 22, 2008 at 7:46:40 am
Aloha Bill,
You didn't rename the BPAV folder something else like BPAV1 that you mentioned in your first post did you? Renaming the BPAV folder causes problems. We make a folder with a date name like 20080421 and copy the BPAV folder and it's contents into it. If you're already doing this, ignore this advice as I don't really have any other ideas. It works fine for us off our hard drive.
Aloha,
Ken
Bill Snyder
Re: xdcam transfer doesn't see my archioved bpav folder files
on Apr 22, 2008 at 2:33:40 pm
Thanks Ken for the advice. I did get the concept of this and have each BPAV folder in a cover folder with the distinguishing name. This appearantly is not my problem still. Thanks anyways. Bill
ken hon
on Apr 22, 2008 at 6:36:45 pm
Aloha Bill,
Bear with me while I ask one more annoying question. Did you install the Sony SxS utility before the transfer utility (I'm sure you did, but just checking). This is the utility that lets the SxS cards be seen by the Mac.
Aloha,
Ken
Bill Snyder
on Apr 23, 2008 at 8:39:31 pm
Hey, it turned out that only the latest FCP Studio 2 updates solved my problems.
ProApplicationsUpdate2008-01.dmg from the FCP site did the trick.
Not exactly sure if it was QT or FCP at this point, but making sure people have the latest updates seems to be the key if you're on studio 2, and OS 10.5.2.
Thanks so very much for your willingness to help!
Bill
Bill Snyder
Re:xdcam transfer doesn't see my archioved bpav folder files
on Apr 22, 2008 at 1:45:12 am
Sorry again about the few capital letters, in the header. I remembered after I posted.
Bill
