SONY HDCAM EX1-workflow with FCP
COW Forums : Sony XDCAM - EX & Related
Vinod Raja
on Apr 20, 2008 at 6:39:30 am
I am using a Mac G5 with a Motorola processor,the one before Intel came to be used in Mac systems. Wish to know from the group if the compression codec of Sony HDCAM EX is compatible with my edit system. On reading about the camera i found that the trans coding software that is given with the camera operates only with INTEL based Macs. Will be a great help if some one here could clarify this. Thanks.
Craig Seeman
Re: SONY HDCAM EX1-workflow with FCP
on Apr 20, 2008 at 1:16:14 pm
Sony XDCAM Transfer 2.5.1 (rewraps to MOV) works fine with G5.
Only Clip Browser doesn't work on G5 and isn't necessary.
Vinod Raja
on Apr 20, 2008 at 6:33:42 pm
Thanks so much for the info Mr.Craig Seeman.This means that i can go ahead and film my next project on Sony XDCAM EX.
Don Greening
on Apr 20, 2008 at 6:54:07 pm
[Vinod Raja] "Thanks so much for the info Mr.Craig Seeman."
Wow. Now that's what I call respect.
- Don
Noah Kadner
on Apr 21, 2008 at 5:49:14 pm
That said, ProRes HQ is something you'll potentially want to use in your EX1 workflow and that does require Intel. It's a really good idea all around to look into the upgrade- everything goes a lot faster especially your renders, etc.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
http://www.callboxlive.com
Rick Diamond
on Apr 22, 2008 at 1:31:18 am
I'm planning on getting the EX1 and upgrading my power pc G5 to accomodate HD. All the specs on the Apple site show that this should be possible. No mention of Pro-res HQ not being able to run on this box. Is it just too slow or incompatible.
thanks,
Rick
