Wind Noise with ECM-674 on PMW EX1
COW Forums : Sony XDCAM - EX & Related
Dexil Rold
on Apr 11, 2008 at 12:39:46 am
I am not a professional but just bought a Sony PMW Ex1. I just tested my new mic for wind noise and it seemed to produce more noise than the built-in mic. I set both channels on internal assuming this was just the built-in mic, then set both to exterior assuming this was for the ECM-674 mic. It created more noise than the built-in mic.
I have never used these before, am I doing something wrong or is there a way to correct this?
Dexil Rold
David Jones
Re: Wind Noise with ECM-674 on PMW EX1
on Apr 11, 2008 at 2:24:53 am
Are you using a windscreen on the 674? Even if you are, you will still get wind noise in most situations where wind is present; that's why you see sound guys and network cameramen using Rycote softies (or equivalent) on their mics. That'll set you back another $120 but, it's the only way to stop the wind. The mic built into the camera is not as susceptible to wind as a shotgun is.
Dexil Rold
on Apr 11, 2008 at 3:11:10 am
I appreciate the information. I was using a windscreen and had the wind noise turned on.
I am checking on how I can buy what you suggested.
Dexil Rold
