Help Needed ASAP To Correct An XDCAM Transfer Problem I Created!
COW Forums : Sony XDCAM - EX & Related
Colin Richards
on Apr 9, 2008 at 3:05:41 pm
I am currently working on a project for a client and I was unable in import a file because FCP kept telling me that I may not have sufficient space.
I found a post on here and I made an amendment to the "Cache" settings in the XDCAM Transfer menu incorrectly. Now when I try to import XDCAM files, the XDCAM Transfer windows doesn't come up. The XDCAM Transfer software just hangs. I un-installed / re-installed the SxS software and XDCAM Transfer software and the XDCAM Transfer window still doesn't come up. I guess I need to just find a way to reverse what I did.
Help needed ASAP!
Michael Palmer
Re: Help Needed ASAP To Correct An XDCAM Transfer Problem I Created!
on Apr 9, 2008 at 4:17:34 pm
Email me a contact number
mikepalmer61@gmail.com
and I'll give you a call.
Good Luck
Michael Palmer
Don Greening
on Apr 9, 2008 at 4:32:04 pm
[Colin Richards] " I un-installed / re-installed the SxS software and XDCAM Transfer software and the XDCAM Transfer window still doesn't come up."
You may have re-installed the Sony Transfer Tool Trying to rectify the problem but unless you also deleted the older Sony Transfer Tool's preference file the same problem will remain. You can follow the path below to navigate to this file and delete it. Once that's done you can start the Sony Transfer Tool and it will default to its initial preference settings.
Macintosh HD>users>yourname>library>preferences>com.sony.bprl.xdcamtransfer.plist
Drag the .plist file to the trash and restart the Sony Transfer Tool.
- Don
Colin Richards
on Apr 9, 2008 at 11:33:37 pm
Don,
I can't thank you enough for your help. Your instructions worked perfectly and everything is up and running again.
Thanks for your assistance.
Colin
Sverker Hahn
on Apr 10, 2008 at 6:39:04 pm
This was probably a wrong import setting i preferences of XDCAM Tranfer.
The settings in FCP is not relevant when importing XDCAM EX-files.
Sverker Hahn, Stockholm
Slower is better!
Sony EX1
Canon XH A1
iMac Intel
Final Cut Studio 2
louise michaels
on Sep 9, 2008 at 12:16:14 am
Can you advise why my Transfer opens with "no image available" in each thumbnail and only info... and no clip plays in the player window either??
Have a G5PowerPC, 10.4.11 and XDCam EX1
thank you in advance!
Don Greening
on Sep 10, 2008 at 10:19:17 am
You need Final Cut Pro v.6.0.2 to make it all work. The XDCAM EX codecs that allow you to see the picture reside with FCP 6 and not the Sony Transfer app.
- Don
