EX-1 firewire to HVRM25U
COW Forums : Sony XDCAM - EX & Related
jerry Parker
on Mar 13, 2008 at 5:36:08 pm
Has anyone confirmed that the EX-1 firewire will work and send an HDV signal to a 25U deck? I have an EX-1 ordered and am looking at getting a deck that will also be DV compatable. Also has anyone been able to record to a firestore or similar hard drive device. I understand that 35MBS is not possible but if the 25MBS is fully HDV compliant this should work.
Michael Palmer
Re: EX-1 firewire to HVRM25U
on Mar 14, 2008 at 4:14:35 am
When the EX1 is in SP (HDV) record mode it can output HDV via firewire. If recording HQ the firewire is disabled.
Good Luck
Michael Palmer
Steve Wargo
on Mar 14, 2008 at 6:26:59 am
Micheal meant to say that it does work under those conditions.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .
Michael Slowe
on Mar 14, 2008 at 6:02:52 pm
Beware though relying too literally on the manual! That indicates that you can record to an HDV deck when shooting in SP mode (firewire) but seems to suggest that you have to be actually shooting in order to do this. There is no mention being able to transfer video from the files on the card. In order to do this you have to be in 'Media' mode, enable the firewire connection in the menu and play the clips with (of course) the deck recoding to tape.
Michael Slowe
