Import problem - "insufficient disk space"
COW Forums : Sony XDCAM - EX & Related
Sverker Hahn
on Mar 13, 2008 at 2:17:45 pm
When I try to import clips to FCP with XDCAM Transfer 2.1.0 I have gotten the message "There is insufficient disk space to import the selected clips" a few times.
But now I get it every time I try to import my clips.
How come?
My scratch disk setting in FCP is a FW disk with 600 GB free.
Sverker Hahn, Stockholm
Slower is better!
Sony EX1
Canon XH A1
iMac Intel
Final Cut Studio 2
Sverker Hahn
Problem solved - sorry ...
on Mar 13, 2008 at 2:35:36 pm
Found the setting, which is in XDTranfer preferences ...
Slower is better!
Sony EX1
Canon XH A1
iMac Intel
Final Cut Studio 2
Colin Richards
Re: Import problem - "insufficient disk space"
on Apr 10, 2008 at 1:47:16 am
Hi Sverker,
I was just wondering how you resolved this problem. I'm encountering the same problem. I have a short term fix by importing long files into shorter clips but I'm interested in a better resolution.
When you have a minute, let me know.
Cheers,
Colin
Tony Tang
on May 17, 2008 at 9:53:05 pm
I encountered the same error message. I did not find any setting in the Preferences window that fixed the problem.
Instead, I had to manually set the in/out points to the beginning/end of the clip and then Import. It worked after manually setting the in/out points.
This happened on a clip that spanned two cards where the first half on the first card gave this error message.
Tony
