Card from EX1 won't mount???
COW Forums : Sony XDCAM - EX & Related
Tim Maloney
on Mar 11, 2008 at 4:43:50 pm
Hello all,
Got some material on a 16 GB card from day one of a shoot.
I don't want to go into FCP - just copy to a little firewire drive I brought with me.
Place it in the express34 card slot BUT it doesn't mount????
Any tips??
Don't want to go into Day 2 with limited recording space. I've got two 8GB cards as well.
Macbook Pro 2.4 4GB Ram every thing up to date although it wants me to run a firmware upgrade 1.3???
Tim Maloney
Rob Brambila
Re: Card from EX1 won't mount???
on Mar 11, 2008 at 5:29:29 pm
Just a quick question. Do you have the SxS driver installed?
If not you can get it here http://www.sony.ca/xdcamex/software.htm
Hope that helps....
Rob Brambila
System Engineer
Promax Systems
rob.brambila@promax.com
http://www.promax.com
Ken Libby
on Mar 12, 2008 at 7:03:34 am
I got a 16 gb card that did the same thing. Funny this is it would work if I pushed it into the slot and held it. Sony is going to replace the card. Curious to see if yours does the same thing.
Don Greening
on Mar 12, 2008 at 7:21:53 am
The other day I pushed one of my 16 Gbyte cards into the EX slot and a message came up that the card format was "unsupported." I pulled it out, reinserted it and all was fine again. Curious.
- Don
Tim Maloney
Card from EX1 will now mount!!!!
on Mar 12, 2008 at 7:52:35 am
Hello all,
So I got this link http://www.sony.ca/promedia/drivers.htm
And all was well using the finder to drag and drop.
I've got copies on my MBP and the firewire for safety.
Also browsed using xdcam transfer.
Cheers
Tim Maloney
Axis Films Australia
Dan Gunn
on Mar 13, 2008 at 6:05:24 pm
Try rebooting your computer between cards.
