Sony PMW-EX1 vs. Sony DXC-637
COW Forums : Sony XDCAM - EX & Related
Aaron Cadieux
on Feb 27, 2008 at 6:06:39 pm
Hello All,
The advertising agency I work for just got a Sony PMW-EX1 to replace our old BetacamSP unit (Sony DXC-637 shooting to a PVV-3 Deck).
So far our downconverted HD from the EX1 doesn't look as good as the SD material shot with our old DXC-637. However, we are uable to downconvert our HD properly. Ideally, we'd use the Blackmagic Multibridge Pro to capture an SDI-HD signal from the EX1 for downconversion. I did not realize that our PC was built prior to PCI-express, so we would be unable to use the Multibridge with our system.
Bottom line question is this. Should properly downconverted HD from the PMW-EX1 look better than SD from the DXC-637? Back in its day the DXC-637 was an expensive camera.
Thanks.
-Aaron Cadieux
Felix Halter
Re: Sony PMW-EX1 vs. Sony DXC-637
on Feb 27, 2008 at 9:29:46 pm
I guess I'm sticking my neck out here, but I have to agree with Aaron.
I'm using the EX1 since a month. When downconverted to SD my old DVCPRO-50 camera with a broadcast lens makes better pictures when it comes to filigrane trees and leaves in the background. I still think that it is impossible to get the same picture out of a camera that costs 1/3 than a good broadcast lens alone.
But for HD the EX1 is a great camera and it fills the gap somewhere between the Z1 and the high-end HD-cameras.
Felix
Aaron Cadieux
on Feb 27, 2008 at 10:40:47 pm
Felix,
Out of curiosity, what method are you using to downconvert? I just ordered the Blackmagic Multibridge Pro, and am hoping that makes a difference. I'll use the SDI/HD output, edit in HD, and use the Multibridge to downconvert back to SD.
Best,
Aaron
Felix Halter
on Feb 28, 2008 at 9:22:38 am
Aaron,
I tried several methods for downconversion via SDI. Please look at this thread:
http://forums.creativecow.net/thread/4/861140
Picturewise it didn't make a difference if I had EX1 downconvert or exit EX1 via DH-SDI and do the downconversion in media100 while aquiring.
Felix
Wayne Carey
on Feb 28, 2008 at 8:02:04 pm
Just to let you know... Blackmagic isn't known for its down-conversion capabilities. Now, AJA is known for this. As for the EX1 down-conversion, did you try using the down-convert out of the camera?
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
http://blogs.creativecow.net/waynecarey
rafael amador
on Mar 2, 2008 at 10:24:18 am
I'm putting the EX-1 footage in a DV sequence. Cut (have RT), CC and right before exporting I set the sequence to Prores HQ, Render all YUV in High precision an Motion rendering BEST. And forget about the field order.
The result is awesome.
PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17"Core2Duo 4GbRAM
JVC DTV-17"/FCS2/AE CS3/COMBUSTION/SHAKE
