"Incomplete" clips won't import
COW Forums : Sony XDCAM - EX & Related
Dale Larsen
on Feb 20, 2008 at 6:20:06 pm
I have just started using a EX-1 & the XDCAM transfer software.
I can't import clips that are "incomplete" because they are on different cards (or folders since I had to dump several cards to a folder during a long shoot)
XDCAM does not want to import them. I can play them in XDCAM transfer but not import.
I also have some files with the extension SMI instead of mp4.
no idea how or where these different extensions come from.
HELP!
need advise please
Sverker Hahn
Re: "Incomplete" clips won't import
on Mar 1, 2008 at 10:01:33 am
Hi, Dale,
I have the same problem. Have you got a solution since your post?
Sverker Hahn, Stockholm
Slower is better!
EX1
Canon XH A1
iMac Intel
Final Cut Studio
Sverker Hahn
on Mar 1, 2008 at 5:33:47 pm
Solved it.
Choose both folders in Transfer tool, select both clips and use the buttons in the logging pane, but I had to scroll down to the bottom to see them.
Slower is better!
Sony EX1
Canon XH A1
iMac Intel
Final Cut Studio 2
Dion Hawley
on Jul 4, 2008 at 12:39:13 am
In the transfer tool select the incomplete clip and then expand the subclips menu next to the source monitor, put a check by both clips or the master clip and then you should be able to import them. Took me two shoots to realize I was missing the footage. How is that for probably missed the money shot!!!!! Kid of feel like Sony should have some kind of automated reconnect, but who knows.
