sxs card in pcmcia
COW Forums : Sony XDCAM - EX & Related
stefan kroesbacher
sxs card in pcmcia
on Feb 15, 2008 at 3:33:52 pm
Hi all,
just wondered:
can a pcmcia-adapter to expresscard work with a sxs card??
as far as i know, the sxs card is going for the pci-express part of
the Expresscard-Slot and doesn't use the USB Part of the Expresscard Specs.
So any current adapter from PCMCIA to Expresscard will not work with
SXS Cards, for they only use the USB protocol.. RIGHT???
please, anyone who tried using a G4 Powerbook with SXS card
please help!!!
gary coler
Re: sxs card in pcmcia
on Feb 16, 2008 at 2:39:59 am
look at the post eariler this month that i posted. i am using an express card reader that works great
Jeff Orlowski
on Feb 21, 2008 at 5:33:57 pm
I'm in the same boat. I need a reader or adapter for a Powerbook G4. It uses the PCMCIA sized cards. The reader you posted Gary is for a desktop.
I just ordered the Dual Systems Adapter,
and found that it doesn't work with the SxS on a Powerbook. So I'm stuck. I found this by Novatel:
But I don't know if it'll work.
Help anyone?
Hilary Koob-Sassen
G4 powerbook useless to EX-1 user?
on Feb 27, 2008 at 9:00:54 pm
A clarification of what one can do with a G4 powerbook and an EX-1 would be great. Otherwise it seems that built into the cost of an EX-1 is a macbook pro or alot of sxs cards.
I think that because it won't handle final cut 6 and xdcamtransfer, you cannot really "transfer" the video onto the G4 powerbook as .mov, but only drag it on as an unusable store. This Bpav folder would need to be put back onto the camera and then recaptured on at least a G5 capable of fcp6 and xdcamextrans, true?
In short, is it true that the G4 is relatively useless to the EX-1 user?
Thanks, Hilary
Dave Rondot
on Sep 2, 2008 at 8:59:16 pm
I tried the duelAdapter cradle and it didn't work. But, I'm wondering if the problem was with the SXS Driver which requires Mac OS 10.4.9 or 10.5 or later. My G4 titanium only has 10.3.9. which is the minimum requirement for the DuelAdapter Cradle. So the question is if I upgrade my OS to 10.5 can I expect the driver and cradle to work. I only want to use this computer as a mule on location to copy my BVAP files to a firewire drive and then transfer and import to my Mac Pro. My G4 will copy the BVAP folder but using original USB it takes two hours to copy 8gb. Any help will be appreciated. I have 30 days to return the DualAdapter Cradle. Thanks.
Chari Hill
on Mar 30, 2010 at 4:26:14 pm
Has anyone tried Sony's SBAC-US10? Midtown Video in Miami, FL has them in stock (305) 669-1117. -Chari
Craig Seeman
on Mar 30, 2010 at 6:57:24 pm
[Chari Hill] "Has anyone tried Sony's SBAC-US10?"
Yes, I use one. It's how I get SxS into my desktop.
© 2018 All Rights Reserved
