Set White Balance=Cannot proceed
COW Forums : Sony XDCAM - EX & Related
Peter Hitchcock
on Feb 13, 2008 at 9:39:18 pm
On A I set the White Balance it sets ok, and switch to B it has a message 'Cannot proceed'
What gives?
Peter
Don Greening
Re: Set White Balance=Cannot proceed
on Feb 13, 2008 at 10:12:01 pm
You have to have the on-screen access for adjusting parameters set to "Partial" instead of "Full" access. Then you'll be able to change your W/B using the switch.
- Don
Chris Babbitt
on Feb 13, 2008 at 10:12:14 pm
Peter, are you speaking of the EX?
If so, check to see if that position is set to ATW in the menu.
Peter Hitchcock
on Feb 13, 2008 at 10:40:24 pm
Yes using EX1 set Other #4 to ATW Couldnt find Partial
About to shoot in a few minutes
Ohmmm
thanks
peter
Nick Righton
on Feb 14, 2008 at 12:54:56 am
I was not able to process white balance with the camera zoomed in. I was able to adjust the white balance by pulling the zoom all the way back and holding a white piece of paper a couple feet in front of the camera.
I wish I was good at one thing rather than average at many, but oh well.
Steve Wargo
on Feb 14, 2008 at 2:31:59 am
[Nick Righton] "I wish I was good at one thing rather than average at many, but oh well"
Nick, stop wishing and make it happen.
Dedication pays off more than anything else. Before long, it will all be natural. In all fairness, the EX-1 menu system is a disaster and has no logic in how it's laid out. Memorize every switch so you can operate that camera in the dark, without looking for things. Be the master. Dwell on your strengths.
Read that book, word for word, without distractions, twice.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1.
Michael Slowe
on Feb 21, 2008 at 5:31:57 pm
Jeez Steve, I've read it 20 times and it's still confusing! Who writes these things - the Z1 was not an easy read either.
Michael Slowe
Steve Wargo
on Feb 28, 2008 at 9:59:59 am
Well, the company is based in Japan and the manual might be written there and converted. It does seem like some very necessary things have been left out. The menus are vague on some points.
Steve Wargo
Tempe, Arizona
It's a dry heat!
2-Sony EX-1.
Chris Brown
on Feb 16, 2008 at 2:29:29 pm
Look up "Direct Menu Operation" (page 20 on my manual). If it's set to "All" then you will get the dreaded "Cannot Proceed" message.
~ CB
