warming up PMW EX1 image
COW Forums : Sony XDCAM - EX & Related
Kevin Kerwin
on Feb 5, 2008 at 3:32:52 pm
I know that Sony is known for the blue cast color palette and Panny is known for a warmer palette, are there any opinions on warming up the Sony image? In-camera or via Color? Filter and in-camera? Just filter? I have an upcoming shoot in a hospital and have concerns over an overly cold look.
Thank you!
Don Greening
Re: warming up PMW EX1 image
on Feb 5, 2008 at 7:06:51 pm
If it was me I'd probably shoot clean (no filters) and do the color grading in post. Sure, you can warm up the look with in-camera tweaking and/or filters in front of the lens but you need to be using a broadcast monitor during your setup to make absolutely sure the changes are actually going to get you the look you're after. Normally the only hard filters I ever use are grad NDs or polarizers (for rejecting reflections in glass or water).
Interestingly enough, I find the unaltered EX picture to be quite neutral rather than being too bluish or reddish. For me that's a good thing because it takes a lot less work in post to achieve what your final look will be.
My .02
- Don
Bill Ravens
on Feb 5, 2008 at 9:46:47 pm
Try this...
Matrix---------------------on
Select---------------------hisat
Level...............................0
Phase..............................+6
R-G................................+75
R-B................................0
G-R................................-18
G-B................................-23
B-R................................-33
B-G................................+11
Steve Wargo
on Feb 6, 2008 at 3:08:26 am
[Bill Ravens] "Try this..."
Awesome answer
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1.
Kevin Kerwin
on Feb 7, 2008 at 5:22:18 pm
Thank you for the input guys.
