Viewing footage in FCP
COW Forums : Sony XDCAM - EX & Related
Mick Haensler
on Feb 5, 2008 at 2:48:40 pm
So the new studio is done, the new Mac system is up and running and Higher Ground Media is a reality. I finally have the chance to start working with this brand new work flow. As many of you know I'm new to XDCAM as well as FCP, a daunting learning curve to say the least. But I digress.
I was messing with the Transfer Utility last night and started putting some footage on the timeline. After I set up my sequence I noticed the output to my monitor was not as sharp as what I was seeing full frame in the Transfer Utility browser when viewing straight off the SxS card. I have 2 Dell 24" hi-defs, one as a work surface recieving DVI from the graphics card and one receiving component signal from a Kona LE card. Is this normal? It looked much sharper on the DVI monitor straight from the card VS the Kona component output. Any input would be appreciated.
Mick Haensler
Higher Ground Media
