Clone an XDCAM disc?
COW Forums : Sony XDCAM - EX & Related
Jeremy Doyle
on Jan 29, 2008 at 8:46:42 pm
Is there anyway to clone an XDCAM disc? I saw somewhere that it could be done with PC software, but we are all mac.
We have a couple 330's a 350 along with 75 and a couple PDW-U1 drives.
Alan Lacey
Re: Clone an XDCAM disc?
on Feb 1, 2008 at 10:35:46 am
I've never tried this but can't you just copy/paste all the files over via the OS.
I've done this to an external drive before importing into FCP.
Alan
Jeremy Doyle
on Feb 1, 2008 at 2:22:03 pm
No that didn't work. I tried. I ended up importing all the clips then exporting them back to a blank disc. However every time I tried to batch export I got error messages so the only way I was successful was to export the clips one by one. 96 clips. Batch would have been nice.
Alan Lacey
on Feb 1, 2008 at 6:14:25 pm
Hmmmm, see what you mean. I just tried copying all the files back to the XDcam disk. That disk seems irreversibly locked?
Alan
Jeremy Doyle
on Feb 1, 2008 at 6:53:19 pm
I wish it was that easy. You would think that it would be.
Wayne Carey
on Feb 4, 2008 at 9:47:10 pm
It was supposed to be available with the release of the Sony Transfer software 2.1 BUT you can see clearly this didn't happen.
Thus, Sony means Soon Only Not Yet or Shipping October Next Year....
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
http://blogs.creativecow.net/waynecarey
Craig Cerhit
on Feb 12, 2008 at 6:56:04 pm
We've been wrestling with this issue for quite a while. We're all Mac here too and I believe there is no current solution for us Mac users. We did try using the transfer software on a PC with two firewire ports and had zero luck. Let's hope Sony can update the firmware on the decks so we can highspeed dub over HDSDI or firewire.
Please post if you find a solution.
Craig
Greedy Productions
Vancouver
Craig Cerhit
Supervising Producer
Greedy Productions
Vancouver, BC
http://www.labwithleo.com
Kenneth Preston
on Apr 16, 2008 at 4:32:20 pm
I'm interested in this topic too. I've been working for three day to make this happen. I finally got it to work with the really poor PDZ-1 V2.1 software and firewire. The idea of cloning a XDCam disc becomes reallllyyyy attractive when it takes ONE hour and FORTY-FIVE minutes to clone a 45 minute disc!!
Has anybody figured this out yet?
Craig Cerhit
on Apr 16, 2008 at 7:02:54 pm
We had limited success using the PDZ software but it took much longer than a HDSDI real time dub. We tried using macs which didn't work. Tried Vista which didn't work... I eventually gave up and were waiting for Sony to release some better software/firmware.
Please post if you have cracked this nut!
Craig
Craig Cerhit
Greedy Productions
Vancouver, BC
Jason Lyons
on Jun 3, 2008 at 12:25:23 am
Ah.. well its slightly comforting seeing that Im not the only one stumped here.
Im giving Carbon Copy Cloner ( http://www.bombich.com/software/ccc.html) a try. I'll post the results, so far so good except USBlllllaaaaaahhhh.
Details:
XDCAMHD Disc with 36.5 Used.
Reading from a PDW-U1 via USB (cough cough)
At 10 minutes = 4.26GB to external via FW800. System is a trusty Dual G5 2Ghz.
Later
j
Jason Lyons
on Jun 3, 2008 at 10:35:54 pm
Success! Carbon Copy Cloner does the trick... But it takes a while.
Updated system info from previous post - I had to move to a different machine because of an edit.
Ingredients:
2.4 Ghz iMac Aluminum or other suitable computer.
Sony's PDW-U1 XDCAM HD reader.
Maxtor Firewire 400 drive
Carbon Copy Cloner
2 hours for a 50 GB disc.
Directions:
1) Download CCC ( http://www.bombich.com/software/ccc.html )
2) Mount the XDCAM disc
3) Open CCC - Select XDCAM disc as source
4) From the Target Disk Menu - choose "New Disc Image"
5) Navigate to your destination drive & Name the Image
6) Make sure the option under Additional disk image options is set to "Create a read-only disk image
7) Make sure the pull down menu for Cloning options is set to "Backup Everything"
NOTE- "Erase the target volume should be greyed out, if not make sure it is not selected.
8) Hit the clone button in the lower right
9) Coffee break and a good time to donate to bombich software for the Reallllllly nice tool! (BTW I am not affiliated with them, wishin I were that smart!)
I am cloning to a new hard drive, freshly formatted Mac Extended. After the cloning process completed I was able to double-click in the image and either wait for it to verify or skip verification and the disc appears on your desktop just as if you had just inserted it into a drive/deck. Next, I opened XDCAM transfer software I simply had to "Add Source" under the file menu. The tool started making proxies just like normal. I imported a few test files into FCP.
At this point the only drawback is the cloning time - right at 2 hours for a 50 GB disc.
Live on!
j
Jason Lyons
on Jun 4, 2008 at 9:26:17 pm
A bit of a confession... I failed to keep it simple... Copying the disc's contents works just as well as cloning in half the time. Has anyone had any long term regrets about backing up or making a second master source disc to a hard drive?
j
Colin Powers
on Jul 31, 2009 at 1:56:39 am
Jason,
How did you just "copy" the files? What program did you use?
I couldn't get CCC to recognize my XDCAM disk at all (23G disk) - CCC announced that the disk wasn't an HFS+ volume and therefore CCC wouldn't have anything to do with it.
I'm mounting the disk to the desktop using a PDW-F70 deck connected to the Mac via firewire in FAM mode.
I haven't figured out any method for making a disk image much less cloning or copying the data back onto a disk.
Regards,
Colin
Colin Powers
Director of Production & Programming
Mountain Lake PBS
http://www.mountainlake.org
Jason Lyons
on Jul 31, 2009 at 2:43:57 pm
I mounted the XDCAM HD disc on Mac OS 10.5.6 via the Sony PDW-U1. It mounts to the desktop like any other drive, so copying was just like copying from another hard drive. The copying method proves to be worthless if you plan on using Sony Transfer tool or any other software looking for an actual XDCAM disc to acquire footage. However if you have a NLE that edits MXF natively then this option might be of value to you.
Regarding Carbon Copy Cloner, I simply pointed CCC to the XDCAM HD disc and told it to make a read-only disc image.
Are you able to mount the XDCAM disc to your desktop? Are you using the latest Sony XDCAM Transfer software 2.9?
Colin Powers
on Aug 3, 2009 at 10:53:06 pm
We are using the v2.9 XDCAM software and OSX 10.5.7
We are using the PDW-F70 deck instead of the U1. Maybe this is the problem.
In any case, CCC will not allow me to do anything with the disk as mounted.
I've noticed that Sony has posted v2.10 of the transfer software which may make this process work with our setup.
Colin Powers
Mountain Lake PBS
