SD out on 330 camera?
COW Forums : Sony XDCAM - EX & Related
Bob Buruchian
on Jun 7, 2007 at 3:40:33 pm
Has anyone else had trouble wirelessly transmitting video out of a XDCAM? Has anyone had success? If so what transmitter system are you using?
tony salgado
Re: SD out on 330 camera?
on Jun 11, 2007 at 5:11:08 pm
Bob,
The HD "Y" analog will never work with a device which is expecting NTSC.
The "Y" output is for HD analog only.
You should look at the SD signal on a wavemonitor to confirm if it is one volt peak to peak and/or if you are having any issues with the encoder on the camera.
Tony Salgado
jiri vrozina
on Jun 11, 2007 at 8:07:13 pm
F-330 downconverts from HD to component analog out.It is all in menu.(PAL)
