F-23 camcorder
COW Forums : Sony XDCAM - EX & Related
Paul Thurston
F-23 camcorder
on Apr 20, 2007 at 4:21:41 pm
I read the color gamut was modified and increased, but besides that, has anybody heard any other improvements on the F-23 camcorder?
-Paul
jan von krogh
Re: F-23 camcorder
on Apr 21, 2007 at 5:36:41 pm
yeah, you can shoot higher framerates it seems. however, i suppose with the introduction of the red camera, it seems logical that the F23 will find very limited use in cinematography.
i own & operate a full hdcam workflow (lenses, camera, vtr, monitors, nles, vector/wave) so i am far for from being anti-hdcam/sr, however i can
Bobbygiles
Re: F-23 camcorder
on May 1, 2007 at 2:40:54 pm
How Much are these cameras going for?
Paul Thurston
Re: F-23 camcorder
on May 1, 2007 at 4:18:03 pm
At the moment the price for the F-23 camera head has not been announced, BUT, the SRW1 HD Portable Digital Recorder has a list price of USD $52500 in the United States.
-Paul
Paul Thurston
WOW- 4:4:4 60P RGB Option for SRW1 announced
on May 1, 2007 at 5:01:25 pm
HKSR-103
4:4:4 60P RGB Option for SRW1.
"The Worlds Only recorder capable of RGB4:4:4 1080/60P recording
Can be installed with current SRW-1 (Firmware update is required)
RGB4:4:4 1 to 60 select fps (selectable frame-rate recording)
- with F23: RGB 4:4:4 or 4:2:2: 1 to 60 fps
- with Genesis: RGB 4:4:4 or 4:2:2: 1 to 50 fps
- Current : RGB 444: 1- 30 fps, 4:2:2: 1 to 50 fps
Dockable Style Connection - F23 or Genesis only
Over/Under Crank Recording
- RGB 4:4:4 1080/60P (playback in 24, 25 and 30fps)
- REAL-TIME PLAYBACK OF 4:4:4 1080/60P IS NOT POSSIBLE
Picture of the card here
Paul
Paul Thurston
Re: WOW- 4:4:4 60P RGB Option for SRW1 announced
on May 2, 2007 at 4:35:58 am
OK, so maybe Sony was not to precise when they wrote "The Worlds Only recorder capable of RGB4:4:4 1080/60P recording." They probably should have written:
"The Worlds Only 12v(60W), lightweight(5.9Kg/13lb), recorder capable of RGB 4:4:4 full 1080 x 1920 /1P to 60P fps / 2:1 compression (25 minutes per tape) / 10-bit linear recording plus motion software that mimics the Arriflex speed change ramp software."
"All that plus a bag of potato Chips..., uh I meant Sony chips"
-Paul
tony salgado
Re: F-23 camcorder
on May 15, 2007 at 12:41:52 am
Paul,
The SRW/SRPC-1 are two piece required for a standalone portable vtr solution.
Together they are closer to 100K in the US.
Currently the SRW1 works alone with the Panavision Genesis camera whereas other camera heads require the SRPC-1 processing unit along with the SRW-1 recorder as a combo unit.
Tony Salgado
Paul Thurston
you are correct
on May 16, 2007 at 2:26:04 am
Hi Tony,
You are correct. The SRW-1 recorder requires that the SRPC-1 HD video processor be attached to the SRW-1 when used with non Sony F-23 / Panavision Genesis camera heads.
-Paul
