Exporting XDCAM HD from FCP to PDW f70?
COW Forums : Sony XDCAM - EX & Related
Ken Libby
on Oct 26, 2006 at 11:14:01 pm
Import works perfectly, edit works perfectly, export, with everything set as shown in the "white paper", crashes FCP the moment I select "Export to Sony XDCAM HD. Disc is formatted correctly. Anyone done this before successfully?
stevec
Re: Exporting XDCAM HD from FCP to PDW f70?
on Oct 27, 2006 at 11:07:03 pm
I was able to export out of FCP to PDW F70, But I did not format the disc. Try it without formatting.
Note: I only had CBR output choices at 25Mbs, there were no settings for 35Mbs, The Sony folks said I should have HD output settings for 35Mbs. Can you check to see if you have these settings for HD 1080 24p
@ 35Mbs VBR.
I can import @ 35Mbs just fine no export to deck at this settings only @ 25Mbs CBR.
Regards
Steve
