Strange issue with SWF import file
COW Forums : Adobe InDesign
Nathan Alter
on May 3, 2016 at 11:29:32 pm
Hello!!
I got a strange problem with Indesign CS5 upon SWF file import. I evaluate it strange cause it worked previously.
Weeks ago when I tried to publish PDF file I tested how will look my SWF file (which I use for panorama images) the test PDF file worked OK. And while importing everything was normal, otherwise I would recognize.
But then I messed with some other programs during weeks. And today while trying to do it again I see that in Media screen there is an issue - in some panoramas a controller (SKIN) embedded into SWF doesn't show up in right place. And some SWF files doesn't look right inside frame at all.
I tried to restore system to previous date - on the date it should work, but the issue remains same mystically. What could cause this?
Nathan Alter
Re: Strange issue with SWF import file
on May 3, 2016 at 11:41:14 pm
This is snapshot of media screen. The controller appears on left up corner, while it's actual place in SWF is bottom center.
10052_indesigncsmedia.jpg.zip
