Illustrations move a bit when deleting or adding pages
COW Forums : Adobe InDesign
Baiba Freimane
on Sep 15, 2015 at 5:59:02 am
Hello there!
I'm facing a strange problem and hope, someone of more experienced ID users can help.
When I'm adding or deleting pages in my document, other illustrations move a bit. They are not on pages I'm deleting, they are on their pages, just with changing position a bit left or right. This can be annoying, when deleting pages 5;6 on 96 pages book and then checking, where are mess again.
Is this normal and I should just breathe deep and do the work as I did until now or is there any solution to this? Maybe I'm doing it wrong?
Kalle Kannisto
Re: Illustrations move a bit when deleting or adding pages
on Sep 16, 2015 at 8:17:45 am
It is possible that Automatic Layout Adjustment is enabled and is doing something when you delete pages. It should theoretically only change the layout if you resize the document or margins, but perhaps deleting a single page could cause some issues as well. See if it is enabled and turn it off if so.
https://helpx.adobe.com/indesign/using/laying-out-frames-pages.html#about_a...
