Can't get default font for new text boxes.
COW Forums : Adobe InDesign
John Perez
on Jun 27, 2015 at 6:35:01 pm
It is allowing me to set my new default font for the entire document, but when I create a new text box it defaults to a different font.
As always thanks so much to you guys...Johnny In Orlando
Dwayne Smith
Re: Can't get default font for new text boxes.
on Jun 28, 2015 at 5:45:14 am
Select your text tool.
Make sure no text frames are selected.
Select the font/size/etc. you want as default in your control panel.
(alternatively, select a paragraph style from the para styles panel).
Now draw a text frame. You'll see it matches the default you set.
John Perez
on Jun 28, 2015 at 9:02:42 pm
I've been using the Rectangle Frame Tool then double clicking inside it which brings up another font. So I should be using the Text Tool whenever I have text and use the Rectangle Frame Tool for graphics and such. Got it. Thanks so much for reply...
